pianotuna
Nov 14, 2013Nomad III
Hi BFL13,
The Yamaha 3000 iSEB (boost 500 watts for ten seconds) as it is loaded the voltage drops. I can't see how an over load would cause and over voltage event. I can see it causing an under voltage event.
BFL13 wrote:lorelec wrote:
An overvoltage event will increase the peak surge current, and may overstress the thermistor.
When you add too many appliances to the Honda EU3000i gen while it is running the other loads, so it pops its breaker, when it pops, is there an "overvoltage event" just before power is cut off?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
