Salvo
Nov 14, 2013Explorer
Some further thoughts. Not sure what the dc voltage at the big input caps is, but it maybe somewhere around 150V. I don't believe the cap voltage goes quickly down to 0V when the converter is turned off. Perhaps around 100V, by design, the converter will stop operation. Now there's very little load on the caps and they will slowly decay. That means when you quickly turn the converter on again, there won't be a huge current surge.
When the OP gets the parts, he should monitor the thermistor temperature. How hot does it get? He should also cycle the converter on/off. I bet it will not fail. No need to baby the thing if you don't have to.
Sal
Sal
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
