Salvo
Nov 14, 2013Explorer
No, that's wrong. The converter will react to the input voltage surge in about 1 ms. That means the converter will just as fast reduce current supply into the caps. It's a closed loop system. The caps will never see a current surge.
lorelec wrote:
Capacitors are not constant power devices, however, and a higher voltage across them will draw more initial current.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
