Salvo
Nov 14, 2013Explorer
The caps are feeding the constant power converter. As soon as input voltage goes up, current demand is reduced. There is no current surge.
On the other hand, during power-up, the converter does not turn on until the cap voltage (I'm guessing) is at least 120V. The requirement for current turn-on surge protection is still there.
Sal
Sal
lorelec wrote:Salvo wrote:
No, that's wrong. The converter will react to the input voltage surge in about 1 ms. That means the converter will just as fast reduce current supply into the caps. It's a closed loop system. The caps will never see a current surge.
The input filter caps are outside of the loop, though. If they were inside of the control loop, there would be no need for inrush limiting.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
