lorelec
Nov 15, 2013Explorer
Salvo wrote:
No, you're changing the conditions of operation. Initially you were suggesting a generator surge, while the converter is in operation, can cause this failure. You thought if ac voltage goes up, so will input current. This is wrong, wrong, wrong!
I can see that I wasn't clear when I was describing the overvoltage possibility. I meant an overvoltage from the generator when the converter is first turned on. All of my suggestions have been at turn-on.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
