ken_white
Nov 18, 2013Explorer
Salvo wrote:ken white wrote:
Unless the 2 thermistors are exactly the same, a matched set, one of them will absorb more energy than the other and very little performance gain, if any, will be achieved - my guess is the tolerance is +- 20%.
That's not true. I agree there won't be perfect sharing, but there will be sharing. It doesn't matter if one of the parts has a 20% higher tolerance. Temperature is the great equalizer in this case. Let's say all the current goes through the thermistor with the lower resistance. This part will heat up and as a result, its resistance increases to that of the other part. Now the parts have equal resistance and they will share. One of the parts will just have a little higher temperature.
If they are matched, the thermal time constant will be reduced and twice the current will flow sooner, which defeats the whole purpose of trying to limit the inrush...
You haven't been listening! It doesn't matter if 5 times the current is flowing. It's still safe. 1 ohm resistance is safe for a 4200uF capacitor bank. The OP only has 2400uF.
The surge limiter is sized to absorb the in-rush created by by the energy stored in the capacitor, which is equal to C times the voltage across the capacitor squared divided by 2.
What does 1/2 * C * V^2 have to do with this?
Sal
The energy is in Joules, which is the specification I stated...
The energy stored in a capacitor is what the thermistor must absorb, and while the energy stored is determined by the (CV^2)/2 equation, the initial movement of charge (current) is the issue.
The thermal time curve controls the charge rate and the joule rating determines how much energy can be safely absorbed.
Why do you not try to understand and only try to show your supposed superiority?
:h
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
