BFL13
Nov 18, 2013Explorer II
I have redundancy in having other chargers I can use until I repair this one again. If I have two in parallel, it was stated that reduces the R by half if they are sharing so that would be a negative if I have that right.
So the latest thinking must be that the 2R025 instead of the 5R 020 isn't such a good idea if the problem is all at start -up and I need more R and higher J?
I would still like something else for the newer design converter that has that bigger thermistor (which has the identity numbers part missing) than the 020.
Not much choice here.
http://www.digikey.com/catalog/en/partgroup/bigamp-sl-series/6367?mpart=SL32%205R020&vendor=570&WT.z_ref_page_type=PS&WT.z_ref_page_sub_type=PD&WT.z_ref_page_id=PD&WT.z_ref_page_event=DC_Link_Table
The converter steady state while at 100a is supposed to be 13a or at least it is rated to use a 15a circuit, being PF corrected. There is a 10R 15a but I am dubious of that 15.
If there were a 10R 025 that would be nice.
But then what about the business where if you are sitting there on shore power for weeks at 13.6v and mention that the higher R could leave the thermistor doing a slow cook? Wait! Now I am muddled on where that NTC fits in with that. :(
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
