DryCamper11
Nov 18, 2013Explorer
Salvo wrote:
It appears the part is failing at start-up. The part is exploding! I don't see any advantage going in series. I think you want to keep the resistance as low as possible. I've shown you only need 0.6 ohm.
The lower the resistance, the higher the current. Power dissipated is I**2R, so initially the power dissipated increases with decreased resistance. A higher resistance will slow down the process - spreading out the energy dissipated over time. A series connection will increase the resistance and each device will only carry half the load.
That said, I'm inclined to agree that 2 ohms is OK, but in general, when specifying an NTC thermistor, you calculate a minimum resistance, then choose one that has more resistance than that minimum. It's seldom that you have to worry about a resistance that's too high, and if you do, it's not because the thermistor will fail, it's because of timing issues - the capacitors don't charge quickly enough.
If it's blowing up on startup, decreasing the resistance isn't the direction to go.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
