DryCamper11
Nov 19, 2013Explorer
ken white wrote:
Unless the 2 Ohm Thermistor can handle 2.5 times more energy than the 5 Ohm Thermistor, it will have less excess energy capacity given the same set of conditions...
It will also allow over twice the surge current to flow, which is what it should be limiting...
And it will have 6.25 times the power being dissipated for the 2.5X increase in current flow. These numbers aren't exact. The faster current flow charges the caps faster, and reduces the current flow sooner. Still, the thermistor is failing due to heating, and that heating is a result of inrush current flow and is proportional to that current squared. Reducing current flow and spreading it out over time are both effective means of reducing the heating that is blowing up the thermistor. Increasing R does both.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
