ken_white
Nov 19, 2013Explorer
Salvo wrote:
Also to consider is the thermal time constant of the thermistor. The 20A, 5 ohm device has a time constant of 194s. That sounds like the device will hold 5 ohms for quite a while.
Sal
Just an FYI, the thermal time constant is calculated using values measured from the maximum hot temperature R to the ambient R.
It can't be used to calculate the negative change in R when operational current flows since I is not known and is a function of the value of C and series resistance of the transformer windings and diode bulk resistance...
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
