BFL13
Nov 23, 2013Explorer II
Salvo wrote:
No surprise. Nothing had changed from the previous thermistor failure. We already knew the initial power-up was not the problem. The problem is P = I^2 * R. Where I is the 10A to 13A when converter starts operation and R is the resistance of the thermistor. The resistance is too high! Use 1 or 2 ohms. It probably also helps if a heatsink is attached to the thermistor.
Sal
It was when the thermistor was already warmed up so its R was low that it got hit with the big current from a "too soon" restart and blew, so how could it help to have a lower R thermistor for the cold start too?
I see the cold start with no load gets the thermistor warmed up and the capacitors done up when I then clamp on and the big current hits, so that is like I was trying not to do with a restart too soon. Same thing. So better to clamp on first. It works on a cold start clamping on last, but I can see there would be less chance of a cumulative effect breaking down the thermistor if I clamped on first.
As I am following the story here, the idea is to hit the thermistor with the high current before it gets warm so its R is still up.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
