BFL13
Nov 25, 2013Explorer II
ken white wrote:
If we look at the worse case current for the 5 ohm thermister, it would allow approximately 170 volts peak divided by 5 ohms or 34 amps of initial current to flow.
If we look at the worse case current for the 2 ohm thermister, it would allow approximately 170 volts peak divided by 2 ohms or 85 amps of initial current to flow.
I know there was the single cycle value being different from actual current (but can't remember in what way ) but how about that 34a limit for the 5R compared with this spec for the converter at 40a?
•MAX INRUSH CURRENT, SINGLE CYCLE: 40 AMPS
Could the 40a translated into real amps be too much for the 34a 5R and ok for the 85a 2R?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
