DryCamper11
Dec 02, 2013Explorer
BFL13 wrote:
I got lost with the thermistor/filter capacitor relationship. Is the MS355R025 superior for that compared with the SL325R020, where I have 2400uF of capacitors?
They should both work. The MS355R025 can handle 41,250uF. The SL325R020 can handle 13,893uF (@ 120VAC). You only have 2400uF. As to which is best, the MS355R025 will be stressed less.
It was mentioned there is a minimum thermistor spec wrt the capacitors, but if both are above minimum does it matter which is used?Not really. One will cost less and the other will be stressed less.
