Salvo
Dec 06, 2013Explorer
It's pretty obvious the 2.5ohm, 9A device won't work well at 13A. I can see why that failed. If you have a 2 ohm, 20 or 25A device, then try it. Worst case, it will fail like the others. It won't subject the converter to any high stress. And best case, problem solved and it works perfectly!
Sal
Sal
BFL13 wrote:
The thermistor is sure protecting the diode bridge--it acts as a fuse!
