- ken56ExplorerJust had issues with mine. It would not charge the battery but the slides and lights worked. I just replaced it with the Progressive Dymanics 9260. Its not hard to do yourself if you have decent access to it. Its usually located behind the breaker/fuse panel. I had to remove my distribution panel to access the converter so you may have to also. Youtube has lots of videos on how to do it.
- wa8yxmExplorer IIITwo sets of instructions
With most modern converters you can hook a digital voltmeter to the battery before you plug in and then plug in and compare the before/after voltages.
Or you can turn on lights/or a 12 volt fan (Fantastic fan is great) while someone else plugs in.. If it's working you will see the light brighten or the fan speed up.
NOW: there are some older converters like the Old Magnetek 6300.. it's actually two units and one can work while the other fails. One runs lights and fans. the other charges the battery a Relay joins them if you are not plugged in. This one is harder to check and I recommend an upgrade (Progressive Dynamics 4600 replacment for the electronic part of the unit) in any case (or a 9200 if it's a stand alone box) - pianotunaNomad IIITurn on a light.
Plug into shore power.
Did the light get brighter? If so, the converter is working. - BFL13Explorer IIOne way is with the RV on battery, no shore power, turn on some lights. Now plug in shore power. If the converter is working the lights should go brighter.
- jdc1Explorer IIIf your RV has a "cigarette" lighter socket, get one of these
https://www.amazon.com/Charger-Voltmeter-USMEI-Aluminium-Adapter/dp/B07JBWGRQL/ref=sr_1_3?crid=23WPFAGFA0062&dchild=1&keywords=12v+meter+cigarette&qid=1588011466&sprefix=12v+meter%2Caps%2C426&sr=8-3 - agesilausExplorer III
wolfe10 wrote:
If you have any RV and don't have "any fancy equipment"= digital voltmeter, BUY ONE.
They start at under $20 and are indispensable for troubleshooting your electrical system.
You can get a bare bones one from Harbor Freight or Northern Tools for less than $10. Which is all you need--a voltmeter and an ohm meter for checking fuses. - wolfe10ExplorerIf you have any RV and don't have "any fancy equipment"= digital voltmeter, BUY ONE.
They start at under $20 and are indispensable for troubleshooting your electrical system. - 2oldmanExplorer IIYou need a voltmeter (not too fancy) and be familiar with its use. A working converter will show 13+ volts at the battery.
- drsteveExplorerWhen you plug the trailer in to shore power, the converter should come on automatically.
- agesilausExplorer IIIProbably no on/off switch. You'd need a volt meter to check it's operation but if your battery charges when plugged into 120V it is working. I installed a digital panel mount volt meter from Amazon to keep an eye on mine, cost about $7 IIRC.
Having RV issues? Connect with others who have been in your shoes.24,347 PostsLatest Activity: Jan 10, 2026
