agesilaus's avatar
agesilaus
Explorer III
Dec 01, 2019
Converter kaput need to buy better one.
I'm fairly sure my converter is kaput. It will not charge my 6VX2 Batteries and I want to go to two banks of 6V batteries. I did work for our summer 7 week trip.
So how do you size a new converter. We have a 30amp system and want to do much more boondocking. Also I have 400W of solar panels not yet connected with a Victron controller.
Any brand recommendations? I think the current one is a Progressive.
  • 45 to 60 amps is fine. I would replace with same rating.
    PD92xx or PD92xx-14.8
  • OP:
    Haven't seen a reply as to what converter you now have. I suggested the PD9245, but if you have a converter that is mounted below the breakers and fuse panel, I would have to rethink replacement.
  • OK just an interim report: It is an Progressive Dynamics Intell-Power, 9200 I assume. Not sure yet what model it is, I'll have to unbox the boroscope I just got and figure out how to work it with my phone. It has 3 X 25 AMP fuses, all good.
    Looks like this
    Thanks to everyone for all the posts.
  • I'd double-check the connections before assuming it's bad. If it is malfunctioning, giving Progresive Dynamics a call in regards to repair/service might be a fruitful exercise; they have better than average support, from what I understand.
    One rather obvious thing to check is to make sure the outlet it's plugged into is receiving 120V power.
  • I would test the fuses, do not go by looks.
    PD 9200 series is still my choice.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
