After four years my converter died. Considering we lived in it for four winters, if that matters, is that to be expected? Also, the new one is being installed today. Did I miss an opportunity to ...
What model converter do you have and is it part of your power distribution system or not?
Most models can be replaced by one of two lines
Stand Alone: Progressive Dynamics 9200
Intergrated (part of power panel) Progressive Dynamics 4600
IN both cases.. GENERALly for most makers the last 2 digits are the converter OUTPUT So a 6345 will output 45 amps.. So will a 9245 or a 4645 So try to match the last 2 as close as you can less you have upgraded batteries and want to upgrade wires as well.
