Veebyes
Oct 02, 2022Explorer II
Start with the basics & check all connections between converter & battery bank.
If you determine that the converter is at fault you might consider upgrading to a multi stage programable charger & get all of your 12V needs from the battery bank, just like boats are set up.
While you are in there get a pure sinewave inverter. Do not get a inverter charger. If one part goes bad the whole thing needs to be replaced. Separate units means just the faulty unit gets replaced.
