facalton's avatar
facalton
Converter not charging batteries
The converter is not fully charging the twin batteries. It will charge them to about 75%. I put an external charger on them and they reached 100% Does this mean I need a new converter or is there a way I can correct the problem?
TIA
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    facalton wrote:
    Converter: Parallax Power Supply. Electronic 7100 Series.
    Parallex 7100 has two versions 71xx and 71xxt The T is two stage and might get you to "Full" Either live with it (Finishing with an external Smart Charger) or upgrade the "Guts" of the unit with a Progressive Dynamics 4600 series (Match the last 2 digits as close as possible)
    The 7100 is a single stage (Float) Charger. it does not do bulk or ansorption the 4600 does. The 7100 T has a "Timed" Bulk phase when you first plug it in.. I'm guessing if you unplug wait a few minutes and re-plug that "Boost" mode will finish the charge (may take a couple replugs)
    Also how accurate is your method of measuring charge?
    A temperature compensated hydrometer is accurate.
    Other methods (Unless lab calibrated) not so much.
  • Start with the basics & check all connections between converter & battery bank.
    If you determine that the converter is at fault you might consider upgrading to a multi stage programable charger & get all of your 12V needs from the battery bank, just like boats are set up.
    While you are in there get a pure sinewave inverter. Do not get a inverter charger. If one part goes bad the whole thing needs to be replaced. Separate units means just the faulty unit gets replaced.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
