DrewE
Aug 22, 2018Explorer III
ScottG wrote:time2roll wrote:ScottG wrote:Same effect if producing the more typical five amps or less?
It may seem to work down there but its regulation circuit is likely to get very hot and fail. I would not run it that way.
Since low voltage is usually a poor utility power connection the converter could be kept off until nightfall when voltage typically recovers. By next day the draw should be fairly small.
The load on the converter doesn't matter much. It's the regulating circuit that needs minimum voltage and current to be happy.
What in a switch mode power supply regulation circuit is sensitive to moderately low voltage? I think most of the control chips just shut down without fanfare if the input or output are too wonky. The actual regulator itself, the switching transistor, doesn't really work extra hard for a low input voltage (and correspondingly reduced maximum load); it's acting as a switch and so not dissipating much power when switched on, and the frequency of operation isn't changing enough to matter.
Many modern switch mode power supplies are rated to work at any nominal input voltage between 100V and 240V or 250V, though I haven't seen that for converters specifically. Rather obviously such a power supply would be perfectly fine with an actual input voltage of 99.8V, which is about as close to a nominal 100V utility power as could be expected.
The PD 9200 manual states that "The INTELI-POWER 9200 series will supply "clean" nominal 13.6 VDC (Normal Mode) power from input voltages that range from 90-130 VAC (205-265 VAC for 92xx-230 models)....At normal input voltages the full load rated capacity is available.
At input voltages less than 105 VAC (205 VAC for 92xx-230 models) the converter may not supply full rated output capacity."
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
