MEXICOWANDERER
Aug 22, 2018Explorer
"The load on the converter doesn't matter much. It's the regulating circuit that needs minimum voltage and current to be happy"
It's not an analog circuit. It's a PWM MOSFET circuit that works less hard at low voltages that it does at full potential. BTDT
IR scanning proves this. Even the WFCO regulation does not suffer.
BUT BUT BUT
Low voltage due to bad connections, arcing, and flashing will kill any regulator from the most to the least expensive. This is why I add tons of MOVS and TVS devices upgrade capacitors to the next higher DC voltage level and upgrade them from 85c to 105c. I can only hope it is enough.
BUT BUT BUT
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
