Bob_E_'s avatar
Bob_E_
Converter Output Voltage
I recently bought an older (1989) camper and have been going through and testing all of the mechanicals, etc. I wanted to test the converter, so I plugged it in to a 120V outlet and then checked the voltage at the two output wires (which were not connected to anything). It measured about 17.5 volts. and hums pretty loud when plugged in.
Is this a reasonable output voltage for this unit? It seemed high to me and I dont' want to fry anything. Also, is the humming normal or do I need a new one?
The ID plate on the converter didn't indicate what the output voltage should be (other than it generically said 12volt). If it matters, the brand is Magnatek.
Thanks!
Bob E.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
