STTH007's avatar
STTH007
Converter problems?
I woke up this morning to the lp detector squeeling and there is no leaks or anything blocking it. If the convertor breaker is shut off it stops the squeeling. Also the power converter keeps cycling on and off also causing the lights to brighten and dim. The battery is at 12.8, not dead, don't know what to do, any ideas, thanks.
  • Did you check the battery disconected from the trailer? You are desvribing a converter that has went bad
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 21, 2025
