Ok tonight I plugged in shore power with no battery connected and still had nothing from the 12 volt side as far as lights and stuff. I had to return the borrowed meter I was using but had no power to anything powered by 12 volts. Also I took the battery and had it tested it was bad. I did check for continuity from the battery cables and had none. I have checked the 30 amp fuses and they both looked good I may replace just to see if that helps. I really don't want to spend $180 on a new converter if I don't have too.
