scottew71 wrote:
This is a link to the flow chart that I followed. http://www.parallaxpower.com/7100/PPS%207100%20Series%20Diagnostic%20.pdf
I got to the point where I pulled the 30 amp fuses and tested the blue wire to ground and that current was good. But then it goes into (note 2) which is kinda foggy to me.
This is getting overly complicated. Converters are easy to troubleshoot.
1. Do you have 120V on input?
2. Do you have 13.6V on output?
3. If you have 120V and no 13.6V, then converter is bad or a converter fuse blew.
4. If you do not have 120V, then find where the 120V is, restore it, then test converter again.
