Flyfasteddie
May 10, 2016Explorer
Reflex439 wrote:
In the mean time.... I still have the issue with the Magnetek 6345, and trying to find a workable solution until I get the solar setup designed and ready to install. I guess I could just be very careful about not connecting to shore power unless the battery disconnect is on. I would just hate to ruin good working appliances because I inadvertently left he disconnect off while leaving it plugged in for several days/weeks.
I completely understand, I went through a very similar process. However, your problem is the nature of the beast. The Magnatek isn't smart enough to know it's disconnected from the battery, and as such it shouldn't be operated that way. You'll either need to figure out a way to always remember to connect the battery when you hook up to shore power (maybe a little red flag tied to the shore power plug) or replace the converter. No matter what you do with your future upgrades, just know that the PD converter will ALWAYS be the best converter for your particular configuration.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
