Reflex439
May 10, 2016Explorer
2oldman wrote:Reflex439 wrote:There's another sign.
If I turn the battery disconnect to on, the voltage drops to a normal level and everything works normally.
Who's this "someone" who forgets to connect the batteries?
Its used by a few people. Mostly my wife and I together. She will also take it solo at times. My daughter and her BF. My Son. Enough minds involved that there is a high probability one of us will forget and fry the electronics at some point.
If a new converter regulates the house 12V regardless if the battery is connected or not, I’ll get one, problem solved. If not I may eliminate the converter all together and have the 12v isolated and maintained by a separate A/C charger and solar charge controller. I’ll just be careful until the update later this season.
MEXICOWANDERER wrote:
Your system is wired all wrong for circuit isolation. If when plugged in your converter delivers more than 13.5 volts for floating the batteries, it is a battery killer. Old converters are hammer and chisel guesswork on the part of the manufacturer. I would be worrying about solar compatibility, down the road.
I am going solar late summer or fall. The current converter isn’t part of the plan anyway.
Is 16.5V more than 13.5V? JK!
I had thought 14V-15V was what chargers typically charge at the high end, working their way down. When I saw 16.5V, I thought regulator issues, not battery charging. Now knowing the battery IS the regulator in the cheaper converters, yea, it was a regulator problem LOL I didn’t know 12V chargers went as high as 16.5V for SLA or GEL batteries.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
