westend
May 10, 2016Explorer
Do this: Take a small wall transformer used to power small DC devices and power it with the output end disconnected from the device. Measure voltage. If you are using a 12V wallwart for this experiment, you'll find that the output voltage is much higher than 12V, more like 15V. Your converter is the same, an unregulated power supply.
Idiot proofing: Buy a different converter. All new converters will work along with any future solar installation. Or, rewire 12V circuits so that distribution comes from the battery and not a common connection close to the converter.
Ground your stereo anywhere a good ground connection can be established (I've always chosen a metal part with good continuity to the frame).
Are all alarms and standby circuit boards isolated when using that disconnect switch? Confirm by measuring draw at the battery terminals.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
