Reflex439's avatar
Reflex439
Converter putting out 16.5V, some appliances don't work.
My RV has a Magnetek 6345 converter installed. I've noticed that when connected to shore power, with the battery disconnect relay in the off or disconnected state, the converter starts supplying 15V to 16.5V on the 12V side, making some appliances in-operable. If I turn the battery disconnect to on, the voltage drops to a normal level and everything works normally. This only happens when connected to shore power.
One side note that might be an issue....
When I installed a new dash stereo, I wired it to the house battery and intend to put in a switch between house and vehicle battery. Currently it is just wired to the house battery. However, there is a wire that connects to the vehicle batteries positive side to retain the channel and setting memory. I don't know if there is any issue with having the memory lead connected to the vehicle battery, while the main power is connected to the house battery, and they are sharing a common ground. I hadn't thought of this when changing the main power from the vehicle to house battery. I thought I would add this just in case it is an issue or creating some sort of weird loop.
Any ideas? Any tests I can run to isolate the high voltage? Is this just a faulty converter?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
