Is it possible to run my 12v lights etc, in our M/H without the converter hooked up? We need to get our batteries checked and will be out of the M/H for several hours. Old Blue
If the converter isn't hooked up and the batteries are removed nothing will work.
I think what you mean is can the RV operate from the converter with the batteries disconnected. If that is the question then the answer is maybe. What converter do you have? Any RV converter newer than 2006 is okay but some older ones require a battery to be in place.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
