TechBill's avatar
TechBill
Converter question
The converter wasn't working so I pulled it out of the pop up camper. It turn out that the fuse holder was loose so I fixed it.
Now it working but it outputting over 15V DC. Is that normal for this type of converter?
It's a B-W Manufacture Series 6400 / Model 6415 converter, I know it quite old but I only wanted to run the 12V DC lamps and refer in the pop up camper from a 120V AC.
I can see that the way the converter is hooked up that it not used to charge the battery.
I have no plan to use it to charge the battery. I will not have a battery installed on the pop up camper.
There a selector switch on the converter itself but I believe it to select between the converter or 12V DC battery to power your pop up camper.
Bill
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
