TechBill's avatar
TechBill
Converter question
The converter wasn't working so I pulled it out of the pop up camper. It turn out that the fuse holder was loose so I fixed it.
Now it working but it outputting over 15V DC. Is that normal for this type of converter?
It's a B-W Manufacture Series 6400 / Model 6415 converter, I know it quite old but I only wanted to run the 12V DC lamps and refer in the pop up camper from a 120V AC.
I can see that the way the converter is hooked up that it not used to charge the battery.
I have no plan to use it to charge the battery. I will not have a battery installed on the pop up camper.
There a selector switch on the converter itself but I believe it to select between the converter or 12V DC battery to power your pop up camper.
Bill
  • Give Randy a call at best converter. I also believe that voltage at 15v is probably ok without battery. But, information is free and Randy will definitely point you in the right direction.
  • TechBill wrote:
    I did look over some modern day converters at RV salvage place which are smaller in size and they wanted a hundred a piece for them.
    My issue is that I am not sure if I wanted to spend the money on this pop up camper and may get rid of it after using it this summer and go with travel trailer next year.
    Bill
    Add a battery and watch the electrolyte level (add water as needed) and it will work fine.
  • enblethen wrote:
    No regulation. Open lead voltage is about right without battery.
    This type will boil you batteries so you need to keep an eye on water level.
    I would think about spending money for a newer style converter. Talk with Randy at Best Converter for best converter for you.
    Bill
    Bill
    Older converters were designed to be operated when connected to a battery, they have poor voltage regulation and lots of voltage ripple.
    If you load the output without connecting it to a battery, chances are the output voltage will lower to an acceptable value, but the ripple voltage will increase too.
    The no battery issue may create problems with some electronic devices.
    Yes I agree with you on this but the way this converter was installed in the Starcraft pop up camper, it wasn't connected to charge a battery.
    Maybe previous owner tried to rewire it separating it from the battery.
    Bill
  • RoyB's avatar
    RoyB
    Explorer II
    I wouldn't use it... Asking for problems...
    Smart Mode Converters the way to go. They will take care of your battery for you...
    Roy Ken
  • No regulation. Open lead voltage is about right without battery.
    Bill
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
