RJsfishin wrote:
If I was an elect tech, I think I would tell you that your converter has nothing to do w/ your A/C
It has EVERYTHING to do with your air cond AND fridge. They need 12v to run the thermostats. Happened to me.
I had my air come on but go back later and it would be off. Then the fridge didn't seem to stay cold.
THAT is what led us to the converter. The A/C will come on but when it shuts off when it hits the set temp it can't come back on. Same with fridge. And let me correct this, it was a forum member that told me the A/C and fridge needs 12v. Thank you btw! 2 service guys didn't even know that.
Check the output of your converter. I've posted this several times but if it helps you here is what happened.
I had 2 service calls on it. All put a meter on my converter and said it was fine when it hit the appropriate output. Long story short I would hear my converter come on but in a few seconds later (after the mobile repair had gone of course) it would make a very low clicking noise. And of course the A/C would stop and the fridge was still warm.
The third guy I made stay and had him LEAVE the tester on AFTER it reached the appropriate output. The dang converter pegged the meter!!! It was putting out 4 times MORE than what it should, and was also boiling the batteries every time I used it.
We replaced the converter and the A/C and Fridge ran fine.
We opened up that converter and one capacitor looked like someone shot it with buckshot and yet it still was working only it could not regulate itself. Goes both ways too much or too little 12v will affect A/C and Fridge on some model MH's.
Good luck I hope you get to the bottom of your problem faster than I was able to! :B
