Sam_Spade
Mar 05, 2020Explorer
As was said, not enough information.
The converter is SUPPOSED to run constantly, dropping to something around 13.3 Volts to "float" the batteries when they are fully charged.
If the voltage really stays much higher than that seemingly forever, then only two real likely causes: Bad converter or worn out batteries.......or after a while on a bad converter, maybe both now.
