JiminDenver wrote:
My bank ate my Megawatt so when I get it replaced, it will be on float duty. Should be fine for that without being borged out.
Can the PMBC-100 run full out for two or three hours? I see they have a 120a model too.
It can run at full out forever. It is meant to be a power supply (such as in a car dealer's showroom), not to be a converter as such. However, I can't see why not to use it as a converter as long as I change the voltage settings to suit the situation.
As a converter my 100 stays at constant 103amps till the battery bank demands a tapering amps when the battery voltage tops out (at 14.8 in my normal setting)
Yes, I would like that 120 amper available now, instead of my 100 (biggest back then) combined with my Vec 40. It doesn't take long before you are down from 140 to 120 anyway on my size of bank (four 6s starting at 50%)
This whole deal is interesting IMO, because I am trying to find a limit on the converter, where usually people want a max.
