Golden_HVAC
Sep 20, 2014Explorer
While it 'can' be done, the inverter is going to take in say 12 amps for a 6 amp output of the converter. So if you can deal with that in-efficiency, then all is well. Yet it is much more energy efficient to run a #8 wire between the two battery banks, and then turn on a switch when you want the 8D batteries to charge the smaller ones from the solar system.
Fred.
Fred.
