BFL13
Sep 20, 2014Explorer II
With two battery banks, I found it worked best to have two separate solar set-ups one for each. I had the two T-1275s on my 130w PWM, 12v set and the four 6s on the 230w and MPPT Eco-W.
The Eco-W is not really able to handle the T-1275s with their high voltage demands (similar to the Screwy 31 situation) but the Solar30 could do the T-1275s.
The Solar30 went to the set Vabs (max of 15v) and then stayed there the rest of the day, but the Eco-W which can be set even higher for Vabs, drops to its Float voltage immediately upon reaching Vabs
The problem there is that the max Float setting is 14.5 so if you want the higher Vabs to stay on the rest of the day, you can't just make your Float setting the same as your Vabs.
However the 6s did get to baseline SG by dark when the Eco-W got them to 14.8 and then dropped to 14.5 for the rest of the day.
It took a while at 14.5 though, so the sun has to be up long enough. A necessary marker for whether the 6s would get to baseline SG on the 14.5 was that the Trimetric has to show the AH count going "over" past zero into positive by about 10AH or so. Reset the AH counter at dusk.
(Indicates gassing at very high SOC more than the 4% allowance Trimetric uses for that--which Trimetric explains in the owner's manual that efficiency goes out the window at very high SOC and the 4% works for the whole range as a good enough average)
BTW the usual story that 6s need over 15v to reach baseline SG seems contradicted by the above experience. IMO this is because on solar the 6s were doing shallow cycles like 80-99 but when doing deep cycles like 50-90s the whole SG thing changes. One drop to 50% will bring the SG "into the red" and getting back up from there is a hard slog so that is where the 15+ v comes into play.
When I sold the 12v set and banked the two T-1275s with the four 6s all on the Eco-W, the 6s got done ok but the T-1275s did not and what's more, the 6s were overdone, losing water while the set-up was still trying to get the T-1275s up to speed. Classic case of mixing different batteries in one bank.
The OP's idea would be fine for a short period of camping like a couple weeks but for a "seasonal" of months you would want to go with separate banks each with its own solar set with a controller that has the right set points for the batteries it is on.
