exp2ex
Jul 11, 2016Explorer
Quick update.
I pulled the converter and just set it in front of the opening on the floor.
Plugged the 220 line in and put the positive lines on the battery.
Everything seems to work in this configuration which leads me to believe that there is a loose wire somewhere. So I unplugged the 220 line and removed the + cables off the battery. I tightened all the lugs on the ground bars, breakers, and 12 v circuits.
All appliances and circuits appear to be working as designed. I turned everything off but left the fridge on to see if it cools down. Previously the check light would come on a few minutes after I pressed it.
We will see how that works out.
Also, I checked the voltage at the battery and the - / + terminals in the converter. Both Read 12.57 V. The NEW battery might have had some drainage from last week prior to me removing the cables. So I will check it later tonight.
So I hope the problem is resolved !
Thanks to all the input.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
