exp2ex's avatar
exp2ex
Converter Toubleshooting Question
My Converter - WFO WF-8955AN
Here is a video of my problem. Little long because of the gremlins in the box !
https://youtu.be/mdQOuhGCluQ
Trying to troubleshoot my issue.
Got a new battery and hooked it up to the camper.
Took the panel cover off the converter.
Put a 12v test light on the 12v feed line and the 12 neg line on the converter.
Test light was very dim. approx. 25% compared to when I put it on the battery prior to connecting the cables.
I start switching all the AC breakers one at a time to see if there is any change in the light on the tester.
Sure enough, the main (30amp) breaker causes a noise and the tester goes to very bright for a moment then goes back to being dim.
