BFL13 wrote:
By the time the charger gets the battery to 14.4 volts, amps will have tapered down so there will be little voltage drop.
Standard PD converters do 14.4 not 14.6, so you want a standard PD converter (NOT their LFP model!!!) in the 45 amp range. Make sure it has the Charge Wizard or built in version of that so you can pick and choose between 14.4 and 13.6 yourself.
It is a good idea to have a battery monitor so you can see amps as well as voltage and see AH count so you know where you are at, and not hit the 13.6 button too soon. I have a Renogy 500A one that does the job nicely and is not expensive, eg.
It seems there is no one correct 14.6v that applies to all LFPs, so you are right to look carefully. It is like "AGM" voltage settings that are lower than for Flooded batts--except there are AGMs that specify 14.7v for charging.
However, if Battleborn says to use 14.6 on theirs, I don't know why anybody would choose not to if they have BB LFPs, and use 14.X instead. Up to the individual LFP owner I guess.
LiFePo4 batteries need >14 volts at the end of their charge cycle to assure proper cell balance. Whether 14.2, 14.4, or 14.6 really doesn't matter much and their BMS will actually shut off charging current when the voltage exceeds the manufacture's setting (14.7v on my Battleborn's).
If one is boondocking and cycling the batteries regularly a converter that delivers a fixed voltage from 14.4-14.6 v will charge quickly, depending on battery bank capacity and output rating of converter. Once charged the generator is usually shut down and the battery starts another cycle. No harm done to batteries with the "fixed voltage" as the battery isn't held at this high voltage for an extended period (measured in weeks and months, not hours or days).
When tied to shore power the recommendation is to just charge batteries to 100% and disconnect batteries, running only on Converter output which was sized by the manufacturer to run all 12v items without the need for a battery. If connected to shore power for months and months, Battleborn recommends to just switch batteries back online a recharge every 6 months.
If one has a converter that won't deliver >14 volts long enough to top balance the cells of a LiFePo4 battery, one economical solution is to purchase a battery maintainer that has "Lithium" capability. A NOCO Genius 2 amp smart charger is only $49 on Amazon and can be directly connected to the battery when running the generator or connected to shore power for topping off and cell balancing. Don't even need to shut off the converter as once the battery voltage reaches the max of the converter, the converter will essentially stop delivering current to the battery. The "maintainer will take over until it's max voltage is reached when cells are balanced and battery is fully charged.
