BFL13 wrote:
You are supposed to add, after "Not recommended..." "...when on shore power and you have lots of time."
You should also add after that, "When on generator and you want fast charging, always use the boost button- that is what it is for."
Ok I wonder why they say that in the manual. They say what the boost does in the first sentence but later say its not recommended. Maybe I'm not understanding it correctly. I'll check into it more.
I agree with you and I have used the boost button before but I figured this test would be just as it sits if I told my wife to turn it on with no special instructions or babysitting.
Next test will be with boost function from the beginning.
Thanks, all input is appreciated.
