azrving's avatar
azrving
Converter vs Battery charger
In this corner we have the Progressive Dynamics 55 amp PD4655 weighing in at 10 lbs, running through 15 feet of 4 gauge cable. The owners manual said that the PD's boost feature should only be used to test the converter so it was left in normal mode.
In the other corner we have the Quick Charge 55 amp weighing in at 36 lbs and running through 8 feet of 8 gauge cable.
The batteries were run down equally as a set to about 12.10 and allowed to recover to 12.29 and 12.30 and separated for charging
start time 4:00 PM
Things are not lining up and I'm not good at spread sheets etc so its a time column and batt 1 column and batt 2 column and the Progressive Ind stated ac amp draw
Batt 1 Batt 2
4:00 12.29 12.30
4:42 13.32 13.99 16 amps ac
5:20 13.35 14.49 12 amps
5:48 13.39 15.05 14 amps
6:12 13.41 15.60 9 amps
Battery bank 2 (Quick charge ) is giving off a slight body odor but per the heat gun is reading 80 degrees
Bank 1 is reading 74 degrees with the ambient being about 73 or 74.
6:17 13.42 15.57
6:30 13.43 15.55 10 amps
6:53 13.46 15.52 5 amps
Starting SG was about 1.237 when starting.
Bank 1 is still close to that and bank 2 is just over 1.250 maybe 1.255
I broke my good glass hydrometer when moving recently so unfortunately this is the cheesy model.
7:04 13.47 15.51 8 amps
8:15 13.52 15.50 7 amps
8:25 13.54 13.56 3 amps
sg 1.245 sg 1.265 3 amps
8:35 13.54 13.51
8:41 13.55 13.46
9:15 13.56 13.36
9:40 13.58 13.30
switched quick charge to bank 1
9:41 13.72
10:03 15.52
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 09, 2026
