VintageRacer
Feb 20, 2015Explorer
A "converter" is typically a DC power source that charges the batteries, supplies DC power to the house loads and has a built in DC power distribution center, with fuses and connection points for the DC loads. Usually it also has the AC main breaker and the AC load breakers for the 120 VAC circuits. While an inverter often has the battery charger and can supply DC for the house loads while plugged in and charging, it really never has the rest of what a converter has, it needs to have a DC distribution fuse block built separately, and the AC breaker box also separate. So no, I am unaware of any single unit that encompasses all of those functions.
A lot of converters are biased towards supplying a constant voltage supply to the house loads, I have one that always supplies 13.6 volts for example. That means that it is not as good a battery charger as one that does a higher voltage bulk and absorption charge cycle. An inverter with a charger, particularly the higher end ones, will have a three or four stage charger that delivers the varying voltage charge that is better for batteries, but can cause issues for some DC loads that expect a constant 13 - 14 volts all the time.
Brian
Brian
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
