pianotuna
Feb 20, 2015Nomad III
Hi,
Add up the wattage of all the devices that will be on at the same time. Purchase an inverter/charger that is 125% of that number for continuous demand.
I prefer stand alone converters and inverters rather than inverter/chargers. If you must go the inverter/charger route try to make sure the charger part is not over 125 amps. That way it will still run on 15 amp shore power.
Here is a place to look--and the owner is an RV'er.
inverter/chargers
inverter/chargers
Cstoliker wrote:
I only run TV, laptops exc...but like the covenance of having the inverter power supplyed though existing outlets. 600 would be more then enough.
Thanks Chris. The name of the device is what I needed.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
