time2roll
Feb 20, 2015Nomad
As said it is an inverter/charger and will work exactly as described. Many RVs come OEM with inverter/charger set up. However they tend to be larger in the range of 2000+ watts inverter and 80+ amps charging and need four+ batteries to operate properly.
But honestly I prefer separate components and recommend a small separate inverter and separate transfer switch. Easy to wire in to the existing outlets if you have done any home wiring before.
GoPower 300w sine wave $171
15a transfer switch $50
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
