mena661
Jul 16, 2013Explorer
You're running 20 feet of wire? I would move the converter close to the batteries and run the 120V line back to the breaker panel or receptacle. 120V isn't as sensitive to voltage drop like 12V is. It's also a lot cheaper wire (120V is). You CAN run the 12V wire 20 ft but you'll never get all 80 amps and likely you'll have to manually trigger the PD to go into boost mode.
