markbrown47's avatar
markbrown47
Converter/charger and auto resetable circuit breaker
I just replaced my Wfco for a Boondocker converter/charger. My trailer came with a 40a breaker In between the charger and battery. The Wfco was a 55a charger, the Boondocker is a 60a charger. Will the 40a breaker affect the 60a Boondocker charger? I get 13.5 volts on the charger side of the breaker and only 12.4 volts on the battery side. I am going to replace the breaker. Should I go back with a 40a or a 60a?
  • Thanks will double check the wiring size and change to a 60a breaker. If I have to I will be pulling new wires.
  • Yes, the breaker will trip repeatedly until the battery charges enough that the current is lowered . I would replace the breaker with a bigger one if the wire size can take the current.
  • The wiring from converter to battery may be too long and thin to get you all 60 amps when charging a low battery, but it might not be that long and thin, so IMO go for the 60amp breaker.
    At least you should get more than 40a.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
