canonkid's avatar
canonkid
Converter/charger trips breaker
I have an Inteli-Power 9160A converter/charger that tripped the 45AMP circuit breaker when it went into boost mode. I contacted the manufacturer and they said I should install a 60 amp circuit breaker. I bought a HI-AMP BUSS 60 amp circuit breaker. One terminal is labeled BATT the other is labeled AUX. I'm not sure if I should connect the Charger to the terminal marked AUX and the terminal marked BATT to the battery bank, since the battery is the one drawing the high current. This circuit breaker is also used for trolling motors and the trolling motor is connected to the AUX terminal since the trolling motor is drawing the current. My situation is the batteries will draw the current. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Dec 27, 2024
