BFL13
Jul 25, 2014Explorer II
wfred wrote:
I am not sure of the SOC of my batteries, since the converter didn't drop to storage mode, I assume they are charging
I don't have voltage loss from my wires. I remove the ring terminal from my batteries and use my multimeter to check voltage at the ring terminals and it reads 14.8 volts. When I connect the ring terminals to the batteries, I use the same multimeter to check voltage at the same ring terminals. The only difference is that now they are bolted to the battery terminals. The voltage reads 13.6. The voltage only drops when the wires from the converter are connected to the batteries. I am not sure if this is because the batteries aren't at 100% charge or if it indicates sulfur on the plates or some other problem.
Thanks for the help,
Fred
This does not indicate anything wrong with the batteries.
The "only difference" is not so much that they are now connected, as that now when connected the wire has current flowing in it, and now you see the voltage drop. No current, no voltage drop.
The amount of voltage drop is related to the resistance of the wires (pos and neg together total) and the amount of current. More current more voltage drop on the same wires.
So everything is normal, except you have a larger voltage drop than you should for that much current, indicating too much wire resistance. No problem on shore power- it will still work ok, but if you want faster charging, less generator time when off grid, you should :
-rewire with fatter wire
-move the converter closer to the battery bank (so shorter wire)
-move converter and use shorter AND fatter wire.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
