westend
May 21, 2015Explorer
Two separate issues here.
You have a 12V system that operates certain devices like lights, fans, water pump, fridge in propane mode. If none of that is operating, regardless of shore power connection, you have a battery problem or connection/circuit breaker/fuse issue.
If no 120V is present when connected to 120V service and you don't have an EMS with delay, you probably have a failing shore power cord or bad connection to source of 120V.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
